HEAVY connecting rod set ( CHEAP )
Gene_French
First Name: Gene
Last Name: French
Board Member Since: 2014
Post by Gene_French » Sun Jun 08, 2025 1:03 pm
for sale : set of early HEAVY type connecting rods for sale ( CHEAP) ... i removed these from the 1st. open valve T engine i worked on 30 years ago ...the babbitt was still very good and i butt ground the caps and ball burnished to STANDARD diameter to restore the fit ... these are too good to throw out and there is very little call to re-babbitt this type rod ... $100 includes postage in lower 48 states ... i can ship outside this area or INTERNATIONAL for actual postage amount ...contact me thru this site ...
Gene French
Gene_French
First Name: Gene
Last Name: French
Re: HEAVY connecting rod set ( CHEAP )
Post by Gene_French » Sat Jun 21, 2025 8:08 am
will be re-babbitting late style connecting rods in next several weeks ... "light " rod sets are $360 + postage , "light " rods with machine cut "X" oil grooves and drilled for dippers are $400 + postage ... will have standard, minus .010" , -.020" and -.030" diameters available ...Gene French
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sat Jun 21, 2025 9:22 pm
should be noted ... the "heavy" rods are being offered outright , no exchange required ... the re-babbitted late series rods require exchange rods ...gene french
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sat Jul 05, 2025 8:36 am
to the top again ..thanks MTFCA
