Looking for a really good 26-27 water outlet
Topic author - Posts: 597
- First Name: Morgan
- Last Name: Blanchard
I am looking for a really good 26-27 water outlet/fan mount. I want to mount a fitting for a period Motometer water temp sensor in it. I have a couple of them, but they have a bit too much rust inside for what I need. If I can’t find a good original, I can use one of the brass repros.
Re: Looking for a really good 26-27 water outlet
Morgan, I have seen some of the beautiful, creative work you have done in your past posts. I can't believe you want to find the best original Ford part and butcher it !!!!! And now I can't find the smiley face icons !
- First Name: Art
- Last Name: Ebeling
- * REQUIRED* Type and Year of Model Ts owned: 1911 touring 14 runabout
EDITED, two different styles and the eccentric picture added. Is one of these what you need? I also have the eccentric if you need it. 75.00 for outlet and 35 for eccentric if that seems fair. Art
- First Name: Robert
- Last Name: Jablonski
Art... If Reno purchases the first version, I'd like to purchase the second version.
- First Name: Art
Reno, Which one, the one with the bolt hole or the other one? Art
It looks like the one without the bolt hole is in the best shape. Can you send me a picture of the inside?
- First Name: Art
Moxie, Which one, the one with the bolt hole or the other one? Reno wants the one without the bolt hole. Art
- First Name: Art
Reno, pm sent with pictures
- First Name: Dennis
- Last Name: Michaud
- * REQUIRED* Type and Year of Model Ts owned: 1909 roadster, 1911 mother-in-law, 1912 torpedo, 1912 touring
- Board Member Since: 2010
I have 2 -- 26-7 water outlets send me an e-mail, Dennis
Congratulations Reno on your second version choice, the one without the bolt holes.
Art,
Thanks for the photos. I sent you a reply to your PM. I will take it and will let you know if I need the eccentric. I might have one and need to check.
