Have You Ever Seen Anything Like This.
Mighty1924
Topic author - Posts: 63
- First Name: Rick
- Last Name: Shaw
- * REQUIRED* Type and Year of Model Ts owned: 1922 Touring. 1924 Coupe
A friend brought me pictures of this and wondered if I knew what it was. My first thought was a Urn. Thought I would post here for those with greater knowledge to help.
ANY IDEAS??
Thanks Rick S.
ANY IDEAS??
Thanks Rick S.
Re: Have You Ever Seen Anything Like This.
I've never seen anything like it. My guess is it's a container to store calcium carbide for use in headlights, a miner's lamp, or even home lighting. Carbide has to be stored in an air and moisture tight container or it will deteriorate.
Hard to tell how big it is. Dimensions would help
Is that a cork on top or brass plug?
Since it says "Complements" on the top & looks like an URN... Might someone's ashes be inside = Funerary urn
Could be a trophy too
mtntee20
- First Name: Terry & Sharon
- Last Name: Miller
Will_Vanderburg
- First Name: William
- Last Name: Vanderburg
Amazingly, your friend brought you pictures that were used on that eBay auction but didn’t show you all of them which would have given you all the answers.
William L Vanderburg
1922 Center Door Sedan
So, what are all the answers? It's not a lamp in any traditional sense. It has no burner or gas jet, nor does it have a place for one. It has no obvious way to mount it. It also says "Compliments of Corcoran Victor", as if it's some sort of commemorative or promotional item. What lamp has anyone seen that stated "Compliments of ...."?Will_Vanderburg wrote: ↑Thu Jun 12, 2025 11:16 amAmazingly, your friend brought you pictures that were used on that eBay auction but didn’t show you all of them which would have given you all the answers.
The Leg Lamp?
Robert Kiefaber
- First Name: Bob
- Last Name: Kiefaber
- * REQUIRED* Type and Year of Model Ts owned: 1906 model F, 1907 model R, 1915 centerdoor sedan, 1921 centerdoor sedan
Maybe a wick burner screws in where the cork is.
Ash tray maybe?
schwabd1
- First Name: David
- Last Name: Schwab
Is the top on that a door/lens from a ‘15 sidelight?
- Last Name: Hjortnaes
Looks like the size of a coffee cup with a cork in the bottom. If smaller it could be a salt shaker.
Like stated previously, no dimensions????
Mighty1924
- First Name: Rick
- Last Name: Shaw
Thank you everyone for your thoughts as what this might be
I'll forward a link to my friend so he can see your ideas and thoughts
Thanks again
Rick.
Thanks again
Rick.
ThreePedalTapDancer
- First Name: Ed
- Last Name: Martin
It’s a complimentary desktop ash tray from Victor.
