Title is "Spark Plug tire inflator" which is partially correct. Yes, the device fits into a spark plug hole, and yes, it inflates tires....box says from flat to inflated in less than 2 minutes, but the pump can be used wherever compressed air is required: inflating beach toys, air mattresses, spreading pesticides or fertilizer, paint, blowing away dust and chaff, etc. NO - it DOES NOT compress gasoline air....outside, ambient air enters the compression chamber in the device, and is pumped into whatever it is that you want inflated.
MADE in Illinois, USA
Spark Plug Tire Inflator REDUCED TO $25.00 + shipping
aDave
Topic author - Posts: 354
- First Name: David
- Last Name: Dufault
- * REQUIRED* Type and Year of Model Ts owned: 1915
aDave
- First Name: David
Re: Spark Plug Tire Inflator REDUCED TO $25.00 + shipping
Spark Plug Tire inflator reduced to $25.00 plus shipping.
Mark Nunn
- Last Name: Nunn
I bought one of those in the '70's and used it for years until I accidentally melted the hose against an exhaust manifold. It works very well and there's no gasoline in the pump, as Dave mentioned. I know because I did the sniff test.
aDave
- First Name: David
GONE. to a new home,
