Looking for apco spring wishbone cap and a hand horn
LittleTimmy52
First Name: Lucas
Last Name: Milatti
* REQUIRED* Type and Year of Model Ts owned: 1917 Model T Touring
Board Member Since: 2025
Post by LittleTimmy52 » Sat Jun 28, 2025 2:18 pm
Edit: after correcting my error, I don't need another drag link spring cap.
I can't seem to find the drag link cap, it's discontinued where ever I see it posted, but I don't mind used. The horn I'm looking for is the side mounted klaxon hand horn the aoogah one with the rod you press down or forward to make it sound. And lastly, the apco spring cap for the wishbone, I too can't find. The only thing I've seen were some expensive klaxons on eBay which I can't afford. If anyone is letting go a horn reasonably cheap let me know, and same for the other parts. Thank you.
Last edited by LittleTimmy52 on Sun Jun 29, 2025 11:50 am, edited 1 time in total.
Re: Looking for apco spring drag link cap, and wishbone cap and a hand horn
Post by TRDxB2 » Sat Jun 28, 2025 2:36 pm
I have some used ones, with some wear.
Try Langs
Wishbone https://www.modeltford.com/item/2736ST.aspx
Drag link https://www.modeltford.com/item/2728ST.aspx
AZTerry
First Name: Terry
Last Name: Loftus
* REQUIRED* Type and Year of Model Ts owned: 26 Speedster
Post by AZTerry » Sat Jun 28, 2025 8:07 pm
sent email
Tparts
First Name: Don
Last Name: Lang
* REQUIRED* Type and Year of Model Ts owned: Multiple years
Re: Looking for apco spring wishbone cap and a hand horn
Post by Tparts » Sun Jun 29, 2025 10:02 pm
We have some available
1-800-872-7871
Lang’s
