Front End Lubrication
Topic author - Posts: 3942
When I rebuild my front ends, I pack the pitman arm ball, and the tie rod ball with old fashioned fiberous wheel bearing grease, but what about the future lubrication? If you wish to remove the ball caps and repack them, good for you. I'm a little bit on the lazy side, so this is what I do. While oiling the oil cups I squirt some oil into the pitman ball area, and the draglink ball too and rock them back and forth. Works for me.
Re: Front End Lubrication
Works for me too!
Ed Baudoux
- First Name: Edward
- Last Name: Baudoux
I do the same. And I use chainsaw bar and chain lube. The heavy summer blend.
Grayling Michigan
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
- First Name: craig
- Last Name: leach
Bar oil is a good idea. I have good luck with gear oil & if you change the rear end as often as we should save it for that reason, then it's free
& save the bar oil for the chain saw.
I failed to mention, I do the same for the wishbone. Sorry I failed to mention that.
big2bird
- First Name: Jeffrey
- Last Name: Hausey
The 600wt oil works well for this. Stays put. I use it on gears on my old Craftman lathe. Doesn't fling off.
