WTB - Joe Morris crankshaft
blauvelt
First Name: Douglas
Last Name: Ogden
Post by blauvelt » Thu Jul 10, 2025 12:48 am
Curious if one is out there.
ModelTWoods
First Name: Terry
Last Name: Woods
Re: WTB - Joe Morris crankshaft
Post by ModelTWoods » Fri Jul 11, 2025 10:29 pm
I'm curious who Joe Morris is, since no one has answered you.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Fri Jul 11, 2025 11:26 pm
Joe Morris made several T crankshafts (couple dozen?) back in the 70’s-80’s. They were fabricated from pins and webs, and meticulously pressed and welded together. Beautiful cranks, but unfortunately most have already broken. I know where some fragments are…
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Sat Jul 12, 2025 1:48 am
here you go.......
Mike Lebsack-Iowa
Last Name: Lebsack
* REQUIRED* Type and Year of Model Ts owned: 11Torpedo, 11 Roadster, 13 Touring, 14 Roadster, 14 Touring
Board Member Since: 2008
Post by Mike Lebsack-Iowa » Sat Jul 12, 2025 10:18 am
Dan, I think I have seen an engine with your main bearing caps and one of these cranks.
blauvelt
First Name: Douglas
Last Name: Ogden
Post by blauvelt » Sat Jul 12, 2025 10:39 am
I figured it was more of hunting for a piece of art and history than anything else. Wasn’t sure if any had survived.
Dan McEachern
First Name: DAN
Post by Dan McEachern » Sat Jul 12, 2025 4:41 pm
Joe Morris was well known in HCCA circles for his knowledge and expertise of one and two cylinder Reo automobiles and rebuilding of the engines. The T cranks he made were because Joe had been fairly successful making Reo crankshafts in pieces and welding them together. Several of the T cranks failed because they were machined with a sharp corner in the fillet of the rear main thrust area rather than a generous radius. I'm not aware of any failures other than the rear flange issue, but perhaps someone else will chime in. AFAIK they were mostly made by Joe, but I understand a few were made by someone who worked with Joe after he stopped. Time wise these were made late '80s / early '90s.
blauvelt
First Name: Douglas
Last Name: Ogden
Post by blauvelt » Sat Jul 12, 2025 5:06 pm
Thank you for sharing. It really seems that a lot of crank failures on rebuilt and even new cranks come down to not cutting enough radius in the crank journals.
flatbroke3
First Name: harold
Last Name: musolf
* REQUIRED* Type and Year of Model Ts owned: 1911 touring 1926 touring 1913 touring
Board Member Since: 2010
Post by flatbroke3 » Sun Jul 13, 2025 9:52 am
deleted my post
blauvelt
First Name: Douglas
Last Name: Ogden
Post by blauvelt » Sun Jul 13, 2025 1:52 pm
Was it a good one?
deleted my post
49willard
First Name: Bill
Last Name: Jones
* REQUIRED* Type and Year of Model Ts owned: 1912 Foredoor
Post by 49willard » Tue Jul 15, 2025 4:40 pm
I had a Joe Morris crankshaft in my 1907 2 cylinder Buick. It failed after a number of miles when one journal rotated relative to the crankshaft throw.
Ujustwaite
First Name: Brian
Last Name: Waite
* REQUIRED* Type and Year of Model Ts owned: B.H. Lawwell Special (1917-1921 Fairgrounds Racer)
Post by Ujustwaite » Tue Jul 15, 2025 10:22 pm
I have one. I'll upload photos soon.
Dan McEachern
First Name: DAN
Post by Dan McEachern » Wed Jul 16, 2025 7:22 pm
"It failed after a number of miles ". The $$S solution for Buicks and Reo's was always a new billet crank from Molex or one of the other crankshaft companies, but ..............
Ujustwaite
First Name: Brian
Last Name: Waite
Post by Ujustwaite » Sun Jul 20, 2025 9:31 pm
viewtopic.php?f=2&t=10178&p=361976&hili ... is#p361958
I forgot that I already posted the photos of mine here. Let me know if you would like more. I have it downstairs in the block but not installed in the car or bolted to an oil pan.
