A Model T Radiator Source
J1MGOLDEN
Topic author - Posts: 1308
- Last Name: Golden
Is there anyone still making Model T Radiators here or in China?
If not, is anyone planning to start building them?
love2T's
- First Name: T
- Last Name: Gates
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1926 Fordor
Re: A Model T Radiator Source
Last I knew Brassworks still is. Just a long wait time.
Ed Baudoux
- First Name: Edward
- Last Name: Baudoux
Brassworks had been out of production for a time, due the the foundry not being able to supply the fittings. They are back in production now.
Grayling Michigan
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
J1MGOLDEN
- Last Name: Golden
Great News!
Thank you!
Thank you!
Until they folded a few years ago, Berg's was the place to go for black-era radiators. I was sorry to see them go.
ModelTWoods
- First Name: Terry
- Last Name: Woods
A member of the San Antonio club, who is a forum member, told me that he had a black T radiator, re-cored by a shop here in San Antonio, a decade or two ago, and that although it was flat tube (as I recall), the shop even put the heavy steel bar between the tubes in the lower part of the radiator between the mounting points.
If you can find a shop that works on older tractor radiators that will be your best bet in getting a recore. The shop here in the Waco Texas area did a recore for me that was fine. The shop also works on heavy truck radiators and builds radiators for replacements. The owner had a source that makes flat tube radiator cores in different sizes that you can have have cut into the size you need and install it. The flat tube radiator cores cool a lot better than round tube in my opinion.
If you have good upper and lower tanks that might be the way to go if you’re not a purist and want a good looking and driving T.
Most of the modern shops don’t work on copper core radiators but pretty much aluminum and if you brought a T or other old radiators they usually are afraid to touch it. It’s cheaper to buy a new one or a good on out of a wrecking yard these days anyway.
Shrshot
- First Name: Kent
- Last Name: Palazzo
- Board Member Since: 2024
I bought a flat tube radiator for my 26 from Brassworks this last winter. A little pricey but I got it in about 2 weeks. Looks good, fit good, and cools great.
