26 Tudor For Sale
Shrshot
First Name: Kent
Last Name: Palazzo
26 Tudor For Sale
Post by Shrshot » Mon Jul 21, 2025 1:27 pm
Selling my 26 Tudor. The driveline is earlier, Nov.1919 by the engine number. Older restoration, not a show pony, runs and drives good.
Engine has aluminum pistons/transmission has Kevlar bands.
$9000 or best reasonable offer.
List of items I replaced over winter.
Rear axle/driveshaft rebuilt, housings were only things not replaced.
New axles
Driveshaft
Modern spool assembly
New U-joint
AC Brakes/equalizer cables
Wire wheels
New tires, tubes, flaps
New Brassworks Radiator
New water pump
Fan hub/sealed bearings
6volt alternator/voltage regulator
6volt starter solenoid
New starter bendix
Transmission screen filter
Foot throttle
Fuel shutoff/Sediment trap
New ignition switch/ammeter
Outside mirrors
Shrshot
First Name: Kent
Last Name: Palazzo
Re: 26 Tudor For Sale
Post by Shrshot » Sun Jul 27, 2025 11:43 am
To the top
First Name: Austin
Last Name: Farmer
* REQUIRED* Type and Year of Model Ts owned: 1922 Touring
Post by 1925 Touring » Sun Jul 27, 2025 1:14 pm
Sorry to hear you are selling your T!
Good luck with your sale!
Wingnut
First Name: William
Last Name: Reep
* REQUIRED* Type and Year of Model Ts owned: 1924 roadsters, 1926touring
Post by Wingnut » Sun Jul 27, 2025 2:10 pm
check your email, thanks
Wingnut
First Name: William
Last Name: Reep
Post by Wingnut » Sun Jul 27, 2025 2:24 pm
Is the diff. a 26-7 or earlier
Post by RajoRacer » Sun Jul 27, 2025 4:12 pm
Appears to be a small drum w/wires & outside brakes.
Shrshot
First Name: Kent
Last Name: Palazzo
Post by Shrshot » Sun Jul 27, 2025 6:19 pm
Good eye Steve. Yes it is a small drum with AC brakes.
Shrshot
First Name: Kent
Last Name: Palazzo
Post by Shrshot » Sun Jul 27, 2025 6:20 pm
Earlier diff. small drum with AC brakes. Everything is new except the housings.
Wingnut
First Name: William
Last Name: Reep
Post by Wingnut » Mon Jul 28, 2025 8:00 am
You mention a 1919 engine, does it have the narrower transmission brake band then.
