ALUMINUM TIMING GEAR SOURCE
John Dow
Last Name: Dow
Post by John Dow » Mon Jul 01, 2019 12:56 pm
Hi Folks. I'm on a search for an aluminum .005 oversize timing gear. I understand the gear manufacturer for the usual parts dealers is serionuisly behind in production. Langs estimates a lengthy wait for order fulfillment. Got any suggestions??
Re: ALUMINUM TIMING GEAR SOURCE
Post by John kuehn » Mon Jul 01, 2019 2:28 pm
Check with Bobs Antique auto parts. He had T parts I needed when the others were out of stock.
SurfCityGene
First Name: Gene
Last Name: Carrothers
Post by SurfCityGene » Mon Jul 01, 2019 4:21 pm
Dan McEachern Gear works in Alameada makes the best timing gears for a Model T. His Bronze one is amazing! I believe he supplies many vendors possibly.
1912 Torpedo Roadster
John Dow
Last Name: Dow
Post by John Dow » Mon Jul 01, 2019 5:51 pm
Thanks Gene, I am looking to replace my Dan McEachern brass gear because it is oversized. I believe I'm running and original steel crank gear that is worn out or maybe the last babbit job was out of whack. Anyways I need a larger gear to get rid of the slop--the rattle is driving me crazy!!!
John Dow
Last Name: Dow
Post by John Dow » Mon Jul 01, 2019 9:49 pm
Sorry, my Dan Mc is UNDERSIZED.
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Mon Jul 01, 2019 9:58 pm
I have a bunch of the old fiber gears that are oversize. to bad you where not closer you could take your pick for free!
Post by Mark Gregush » Mon Jul 01, 2019 10:55 pm
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Tue Jul 02, 2019 1:33 am
If you need an oversize cam gear, I have a pretty good assortment of them in stock. Not sure what you mean that your bronze gear is undersize unless it was a special that we intentionally cut undersize for some reason in the past. My e-mail is dmcgearsatyahoodotcom. replace the at and dot with the usual. Dan
