rear end bearing sleeves
Colin Mavins
First Name: Colin
Last Name: Mavins
Post by Colin Mavins » Mon Aug 04, 2025 7:41 pm
I have found in Dads garage nos bearing sleeves , I am guessing they are soft as apposed to the hardened sleeves for sale by vendor. Should I buy hardened sleeves or use the Nos sleeves. Back in Dads day you would use inner sleeves from another diff and use them as outer sleeves to complete your rebuild. Thanks in advance for your wisdom Cheers Colin
Re: rear end bearing sleeves
Post by speedytinc » Mon Aug 04, 2025 8:02 pm
Use them. Better to wear the sleeves than the original hyatts.
Post by Jerry VanOoteghem » Mon Aug 04, 2025 8:06 pm
Are the sleeves marked "Ford" or "Hyatt"? If so, definitely use them.
Moxie26
Last Name: Jablonski
Post by Moxie26 » Mon Aug 04, 2025 8:08 pm
Dad had a good idea... And as long as you have two lefts and two rights on those NOS Sleeves, you're set.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Mon Aug 04, 2025 11:44 pm
there was some repro junk out there in years past do be cautious!
Colin Mavins
First Name: Colin
Last Name: Mavins
Post by Colin Mavins » Thu Aug 07, 2025 7:49 pm
They are marked Hyatt, I am building a spare diff and while cleaning out the garage I have found all nos part ect the cast carrier and the housings.
