Hartford Tubes
Topic author - Posts: 3944
Hartford Tubes
Has anyone experienced removing a valve stem from a current Hartford tube. I've been doing it for years on regular rubber stem tubes, but these valve stems look like plastic. Am I correct or ?
Re: Hartford Tubes
Can anyone tell me if they have successfully cut off a Hartford valve stem, and replaced it with an original Schrader?
Re: Hartford Tubes
I hope somebody will try it, just to settle the question, and install a new valve in the stem to see if it works like the valves always have.
Re: Hartford Tubes
Thanks Steve. I really feel uneasy about removing that valve stem. It seems like it is plastic! I guess I'll just have to do it, and if it doesn't work out, I'm out the cost of the tube.
