Model B cylinder head
Gene_French
Topic author - Posts: 1090
- First Name: Gene
- Last Name: French
- Board Member Since: 2014
Model B Ford cylinder head ... often used on Model A engine to get a slight increase in compression and performance ... a period correct application , BUT requires the use of the 3 bolt Model B waterpump ...price is $75.00 + actual postage or pickup at my site in northern Colorado ... Gene French 970-581-two eight zero eight
MT5Tony
- First Name: Tony
- Last Name: Cerovski
- * REQUIRED* Type and Year of Model Ts owned: Six 1926-7 Roadsters, One 1925 cutoff, & One-27-Coupe
Re: Model B cylinder head
Hi Gene,
I will purchase the Model B Cylinder Head for $75.
I will need pay you additional $ for shipping.
Thank you,
Tony
I will send you an email shortly.
Thank you,
Tony
tman12
- Last Name: Willams
- * REQUIRED* Type and Year of Model Ts owned: '09 Roadstr, '12 Touring, '26 Fronti Speedster
Gene! Hi From Iowa! If the deal falls through let me know & I would be glad to purchase the B head! Thanks John
Gene_French
- First Name: Gene
- Last Name: French
B head is spoken for ...thanks Tony ... i will get cost of shipment for the head and email ... also , thanks for your interest John ...Gene French
John from Iowa, i have a really nice clean one, with a freshly milled surface, but I'd hate to say what the postage costs would be.
Gene_French
- First Name: Gene
- Last Name: French
Allan:
postage on this head from Australia would probably be over $200U.S. ... i had a quote for a linebore unit to Au. for over $320U.S. ... i did not check on the exchange rate for Pacific Peso to U.S. dollar , but i bet the number would scare many people ...Gene French
The huge costs are a result of everything being posted being carried by air. When we had a sea mail option, postage was reasonable. It makes selling things to you guys in the USA difficult. Having you send me stuff is usually prohibitive, because of the unfavourable exchange rate. I have to really want stuff if it has to come this way.
What really gets on my goat is the Ebay shipping charges, Bib overalls can vary from $30 to $90 for the same purchase. Postage across the Pacific is not dependent on post/zip codes of the sender or receiver, so the difference can only be getting the item to Ebay's distribution centre from a US zip code.
