WINFIELD MODEL S CARBURETOR
Roadsterguy
First Name: Rene
Last Name: Gonzalez
* REQUIRED* Type and Year of Model Ts owned: 1927 tudor
Post by Roadsterguy » Tue Aug 26, 2025 1:07 pm
Rebuilt Winfield model S-AA-D. DOWNDRAFT. New gasket kit installed. Intermediate and high speed compensators are correct and stamped AA. All passages were thoroughly cleaned and carb was ultrasonic cleaned before reassembly. Nos choke cable clamp and linkage arm installed on correct choke horn stamped S-41-B. Throttle is smooth. AA winfield carbs flow about the same cfm as a 81 stromberg so its good little upgrade if your running a banger engine. Comes with an original (not copy) of the installation instructions and extra set if gaskets. $1000 shipped to your door. Located in La Mirada Ca
ewdysar
First Name: Eric
Last Name: D
Re: WINFIELD MODEL S CARBURETOR
Post by ewdysar » Tue Aug 26, 2025 1:12 pm
email sent
Roadsterguy
First Name: Rene
Last Name: Gonzalez
Post by Roadsterguy » Tue Aug 26, 2025 1:39 pm
WINFIELD IS STILL AVAILABLE.
