Oil on plugs
Will
First Name: Will
Last Name: Copeland
* REQUIRED* Type and Year of Model Ts owned: 1915, 1919, 1923 TT
Oil on plugs
Post by Will » Fri Aug 29, 2025 6:57 pm
Had a small show to go to today, I noticed some oil on my sparkplugs, Is this normal? The car does not smoke at all.
As Tom Sellick told Marston in the movie Quigley Down Under, I told you I dont have much use for handguns, I never said I didn't know how to use them!
Re: Oil on plugs
Post by speedytinc » Fri Aug 29, 2025 6:58 pm
Oil on the outside of the plugs or inside around the electrode?
Will
First Name: Will
Last Name: Copeland
Re: Oil on plugs
Post by Will » Fri Aug 29, 2025 7:20 pm
John, On the outside of the plugs
Re: Oil on plugs
Post by speedytinc » Fri Aug 29, 2025 8:06 pm
Leaking around the threads or from the crimp of the base to porcelain? Its a mix of fuel & oil before combustion.
Threads can be sealed with a bit of anti seize. I prefer the conductive stuff. Mine is aluminum based.
There is a copper version also.
