Connecting Rod bolts?
Topic author - Posts: 5527
- Last Name: Hatch
Anyone know the modern part number for the connecting rod bolts. I think it is a Chevy rod bolt, which one? Thanks Dan
Re: Connecting Rod bolts?
- Attachments
- rod bolts.png (83.23 KiB) Viewed 889 times
- Last Name: Hatch
Thanks John, I need about 10 sets. Dan
- Last Name: Hatch
Yes, just was not sure of the use. Dan
NoelChico
- First Name: Noel
- Last Name: Chicoine
- * REQUIRED* Type and Year of Model Ts owned: 1920 roadster, 1923 Touring, 1926 Coupe
Most engine rebuilders use new bolts and discard the ones taken out of the Chevys. Since we don't torque near as far, I ask the shops or local mechanics for their used bolts. I'm cheap!
BobUkPipedream
- First Name: Robert
- Last Name: Dyer
Beware of some of the bolts that were being sold in the blue and white Model T packs. Mine went to torque once, then stripped on the second attempt. Ended up using the original bolts again.
