Pedals
Cody Winters
First Name: David
Last Name: Winters
Board Member Since: 2023
Pedals
Post by Cody Winters » Mon Sep 15, 2025 8:59 pm
The 25 fordor i'm looking at has a 25 style rear axle with a Ruckstell and the engine number is that of a 25, but it has wide 26-27 pedals. when exactly in production did they phase in the wide pedals? they aren't slip on pedal accessories, they definitely are part of the pedal stalk. and the engine displays all the characteristics of a 25. if you can't make out the number on the block it's 12372515
Re: Pedals
Post by RajoRacer » Mon Sep 15, 2025 10:19 pm
With the bolted trans. cover to the block indicates a late '25 & would have the wide brake drum & associated wide pedals.
Re: Pedals
Post by TRDxB2 » Tue Sep 16, 2025 12:36 am
You didn't mention the VIN on the title if it matched or not. Its possible that this was a replacement engine and stamped with the original engine. I does look like the engine has the pigs ears on the transmission housing bolted to the block Then there's the possibility of confusion about the production of engines in those months.
engine config.png (248.53 KiB) Viewed 752 times
Mike Silbert
Last Name: Silbert
Re: Pedals
Post by Mike Silbert » Tue Sep 16, 2025 8:36 am
According to Bruce McCalley and the production records that serial number is on the 5th day of 1926 production.
If that is the real serial number then it probably was built with leftover parts, Henry did not worry about "correct" parts.
All 4dr bodies were made by outside suppliers (with many detail differences) and the only change was the cowl changed to match the new 26-27 hood.
During year changeovers a lot of odd ball cars were built.
Is that the original engine?
Is that the original VIN?
Re: Pedals
Post by DanTreace » Tue Sep 16, 2025 8:59 am
The engine and wide pedal transmission are the Improved version. Obviously was swapped into your ‘25 -24 model year Fordor since your T isn’t Improved model with crowned fenders and sitting on the Improved Car frame.
You may be able to date the body by features, the dash shows the butterfly for choke to carb, by mid ‘25 that setup changed to the single dash combo choke and carb adj. The butterfly was eliminated.
Cody Winters
First Name: David
Last Name: Winters
Re: Pedals
Post by Cody Winters » Tue Sep 16, 2025 9:12 am
here is the photo of the dash, the dash choke is an earlier style dual choke and mixture set up.
Last Name: Hatch
Re: Pedals
Post by Dan Hatch » Tue Sep 16, 2025 9:17 am
Interesting: Look at the engine pan with two holes under carburetor. These were made for dual use, carb or vaporizer. I have been told “They never made those.”
I had those that came out of Ford dealership in the 50/60’s.
See yellow circle in picture.
Chris Barker
First Name: Chris
Last Name: Barker
Re: Pedals
Post by Chris Barker » Tue Sep 16, 2025 9:57 am
I also have one of those two-hole pans that they never made!
Re: Pedals
Post by DanTreace » Tue Sep 16, 2025 10:06 am
The choke knob is round, and under the dash will be a rod with triangle bend end to adj. the carb setting.
Yes, seems to be a '24-'25 body, the patent plate below the dash is the rectangular style, these are used 1919 to March 1925. Sometime in March 1925 the 'clipped' or angle corner patent plate were used to end of production, July 1927
