What have you done to/with your Model T in September?
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Thu Sep 18, 2025 7:23 am
Made a sleeve between the timer and the adjustment rod; used grease. There was that much play. (background is 60 grit)
I had used screws with a plus + in order to attach the rain gutters to the top wood and tried to hide my sins with some black silicone.
timer sleeve.jpg (20.63 KiB) Viewed 2207 times
cover sins.jpg (59.2 KiB) Viewed 2207 times
Vern (Vieux Carre)
South Park Zephyr
Last Name: Francis
Board Member Since: 2022
Re: What have you done to/with your Model T in September?
Post by South Park Zephyr » Thu Sep 18, 2025 8:42 am
I finally got the chance to install the wood bed kit my wife got me for Christmas , added disk wheel covers (thanks to Herb Iffrig),mad the support arm for my passenger side mirror, and went on the Hillbilly tour.
babychadwick
First Name: Chad
Last Name: Azevedo
Post by babychadwick » Thu Sep 18, 2025 9:05 am
I managed to finish wrapping the wheel. Believe me it takes a while to get it right.
haydonr
First Name: Haydon
Last Name: Rowe
* REQUIRED* Type and Year of Model Ts owned: 1924 Roadster Pickup, 1919 TT, 1913 Raceabout, 1912 Tourer
Post by haydonr » Thu Sep 18, 2025 8:59 pm
Got our '12 back from the paintshop... now for upholstery...
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Fri Sep 19, 2025 10:21 am
Haydon,
Beautiful looking paint job. Is it black?
Since you are bown under and the car is right hsns drive, I presume the body was made by Wm. Gray & Sons. I'm curious; What is the body number? It will be stamped into the wood on the seat riser in front of the gas tank cover, and on the underside of the fore-door, and one of the back doors.
Keith
haydonr
First Name: Haydon
Last Name: Rowe
Post by haydonr » Fri Sep 19, 2025 4:17 pm
Hi Keith,
It's definitely blue in the right light (a slight purple tinge in some lights).
The body is a modern repro that came with the project when we bought it in pieces from a deceased estate. It should technically be a slab side based on the 117,xxx engine number, but this is the body that the previous owner imported for it and we weren't going to throw it away (plus I like this shape).
Haydon
Jones in Aiken SC
First Name: Gregory
Last Name: Jones
Post by Jones in Aiken SC » Fri Sep 19, 2025 9:17 pm
Got the top irons pretty much ready to go to get a top put on my 12 Roadster, along with some pinstriping. Hopefully all done by end of October!
haydonr
First Name: Haydon
Last Name: Rowe
Post by haydonr » Fri Sep 19, 2025 9:51 pm
Also just taught my wife to drive the '13 today 8-)
Tadpole
First Name: Tad
Last Name: Glahn
Post by Tadpole » Sat Sep 20, 2025 8:53 am
Went Pawpaw pickin’, the cat helped
babychadwick
First Name: Chad
Last Name: Azevedo
Post by babychadwick » Sat Sep 20, 2025 9:57 am
I also started on the garage pouring the slab by hand and dug out some parts that survived multiple hurricanes and moves and set them together to start thinking on the next build.
Replacement (unstamped) '14 block, early cross drive mag, DR4 mag (combination mag and dist), early hoggshead, nims water pump, and a fronty ported and worked over by Sherman.
henryford2
First Name: Joseph
Last Name: Andulics
Post by henryford2 » Sun Sep 21, 2025 6:25 am
Putting them to bed for the winter and moving them around so the wife can get her car in the garage!
rwephill
Last Name: Evans
* REQUIRED* Type and Year of Model Ts owned: 1925 TT C-Cab
Post by rwephill » Sun Sep 21, 2025 8:09 pm
Built a grain bed for the TT.
“You don’t have to go fast… you just have to go.”
Jevil
First Name: Jens
Last Name: Willeke
* REQUIRED* Type and Year of Model Ts owned: 1927 Tudor Sedan
Post by Jevil » Fri Sep 26, 2025 3:51 am
Had an easy job this month - I just bought one:
1927 Tudor Sedan - black (of course)
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Fri Sep 26, 2025 4:14 am
Congrats Jens! It's a beaut'
Vern (Vieux Carre)
Shrshot
First Name: Kent
Last Name: Palazzo
Board Member Since: 2024
Post by Shrshot » Fri Sep 26, 2025 2:22 pm
Took the Tudor to our family reunion. Was a great ride and a great day.
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Sat Sep 27, 2025 2:08 pm
Drove the T to the gas station for the first time in decades and put in $10 of 87 non-ethanol. Serignan's gas station opened in 1927, has stayed in the same family, so it seemed fitting. This is a photo of it from 2017 and is within a mile of the Ford assembly plant.
Vern (Vieux Carre)
CatGuy
Last Name: Hunt
* REQUIRED* Type and Year of Model Ts owned: '26 Runabout
Post by CatGuy » Mon Sep 29, 2025 12:47 pm
I drained the 2 year old fuel and bought a new battery. I'll hopefully do more when I feel up to it.
