fore and aft slack
r4rabbitx
First Name: Reni
Last Name: wayne
* REQUIRED* Type and Year of Model Ts owned: 1926 Ford Model T touring
fore and aft slack
Post by r4rabbitx » Mon Sep 22, 2025 8:22 am
On a Model T Generator , how much fore and aft slack is allowable in a 26-27 Model T generator? The gear seems to be tight on the shaft and the generator works normally, but I can move the shaft back and forth about 3/32".
Re: fore and aft slack
Post by speedytinc » Mon Sep 22, 2025 8:34 am
Minimal to none.
There are spring steel bearing tensioner spacers available to go under the rear bearing to take away that slop.
You can also drop in an extra generator felt seal in under the bearing that will take out the play.
