Metal ring that fits in wood felloe valve stem hole?
Topic author - Posts: 2967
- Last Name: Hjortnaes
Does anyone know if Stutzman puts the ring in the valve stem hole or do you need to purchase it somewhere?
This is for a wood felloe.
CALLEN1234
- First Name: Charlie
- Last Name: Allen
- * REQUIRED* Type and Year of Model Ts owned: 1916 Touring
Re: Metal ring that fits in wood felloe valve stem hole?
Stutzman installed the ring in my wheels.
BigAl
- First Name: Alan
- Last Name: Stein
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring (August 1911)
Stutzman does exceptional work. When you get them back they are perfect and all you need to do is paint them. Only suggestion is if you want the stamped joint plates which denote the wheel manufacturer you need to supply them because he uses blank ones. Great guy to work with.
Alan
That was my next question. I pulled off my old plates and was going to paint them.
I am wondering if he has to heat up the rims to install them or can I paint them before I deliver them to Noah? Does he just press them on?
I have seen new wheels that had the tubes made from copper tubing. (Stutzman?)
Ask him directly.
Ask him directly.
Jones in Aiken SC
- First Name: Gregory
- Last Name: Jones
- * REQUIRED* Type and Year of Model Ts owned: 1912 Roadster, 1926 Coupe
Stutzman fabricated them and installed them in the wheels he did for my 1912 Roadster.
CALLEN1234
- Last Name: Allen
The hubs and rims that I took to Stutzman were painted.
