Does this original speedster look like a commercial or homemade body?
BuddyTheRoadster
Topic author - Posts: 135
- First Name: Chris
- Last Name: Rini
- * REQUIRED* Type and Year of Model Ts owned: 1923 roadster
A client sent me this picture of a speedster his grandfather built. The client would like to know if the body is factory or homemade? I think it looks close to the Champion model A body, but I invite your opinions.
Chris
Chris
Re: Does this original speedster look like a commercial or homemade body?
Need to match to the passenger side body line
- Attachments
- speedster 2.png (323.14 KiB) Viewed 859 times
Similar, but not an exact match. Looks manufactured, and manufactured speedster bodies probably had variations within a single maker's products over time.
ewdysar
- First Name: Eric
- Last Name: D
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1915 Speedster #32, 1916 Touring, 1927 Runabout
To my eye, it looks to be a closer match to the Model "C' in the advertisement. The louvered hood and the cowl to hood transition angle are very similar to the drawing. The car in the photo looks to have taken the suggestion in the advert to remove the stock Ford fenders, running boards and splash aprons, but it still appears to be running the stock Ford radiator as described in the advert copy for the "C" version.
Keep crankin',
Eric
Keep crankin',
Eric
The cowl line is "swept" back on the advertised body unlike the one in the photo - it's straight - not the same.
- First Name: Jeff
- Last Name: Humble
- Board Member Since: 2006
Regardless of the make and model of a particular manufacturer, to answer the original question, it looks to me like a manufactured body not a homemade body.
AndyClary
- First Name: Andrew
- Last Name: Clary
Looks similar to C. But you have to remember that the same bodies were sold under a variety of names.
Andy
Andy
Dodge
- First Name: Dodge
- Last Name: Riedy
- * REQUIRED* Type and Year of Model Ts owned: 1915 Ford Center Door
Manufactured. There were so many short lived manufacturers its hard to pinpoint the exact manufacuturer of some of these bodies.
Hard to match it, but some similarities. The builder of the car did make some modifications to the original design.
Top of back seat, length of cowl, steering wheel close to dash.
This link has the instructions for thr RED-I-Cut need to scroll down https://www.mtfca.com/discus/messages/3 ... 1386522911
