I believe that I have seen a water pump that is in between the upper hose to the cylinder head for a Model T. This is a speciality build and it will need a water pump. The standard location for it is out as there is no more room on that side of the engine.
It is driven from the fan belt and I thought I found one at Hershey but it's not correct.
TIA
John
WTB Upper hose to Head Water Pump
Re: WTB Upper hose to Head Water Pump
Nims is one brand. Think off the top of my head they were made in Stockton California.
Kevin Pharis
- First Name: Kevin
- Last Name: Pharis
Hope you don’t need much of a “pump”, the Nims type pumps are almost novelty. How are you getting water into the block…? If you have room for the original water pipe and inlet, there are several pumps where the pump housing is at the front, rather than the typical Texas T style at the water inlet passage. Here is a Boyd pump
Here is some info on the NIMS .....jmemjr wrote: ↑Thu Oct 23, 2025 8:52 pmI believe that I have seen a water pump that is in between the upper hose to the cylinder head for a Model T. This is a speciality build and it will need a water pump. The standard location for it is out as there is no more room on that side of the engine.
TIA
John
There is another style on eBay for sale $275 https://www.ebay.com/itm/226455591620?c ... VrBqrPxqbg
jmemjr
Topic author - Posts: 72
- Last Name: Memmelaar
- * REQUIRED* Type and Year of Model Ts owned: 1912, 1914, 1915
Got the one on E-bay! thank you everyone!
