1926-27 T Pickup Bed Center Pan
TA Man
Last Name: Partain
Post by TA Man » Fri Oct 24, 2025 2:01 pm
I'm looking for anyone who has an original "FLOOR REAR CROSS MEMBER HOUSING" for the 26-27 T Pickup Bed. This is the center pan that is located over the rear crossmember. I'd like to get some profile photos of the pan out of the bed, but in the bed would be ok too. Also, does anyone have the T part number for this piece?
Re: 1926-27 T Pickup Bed Center Pan
Post by Original Smith » Fri Oct 24, 2025 3:12 pm
Are you sure it's called a housing? I thought it was a cover?
Post by Scott_Conger » Fri Oct 24, 2025 3:20 pm
Dan
good luck...you should get what you're looking for...99% of us know what you're talking about and what you call it makes no difference.
welcome to the affliction!
Post by DanTreace » Fri Oct 24, 2025 4:03 pm
T-48815 is part number of the '26-'27 Housing (rear cross member) as noted in the Price List of Body Parts book.
Bed plate0004.jpg (37.49 KiB) Viewed 726 times
Bed plate0002.jpg (33.43 KiB) Viewed 726 times
Bed plate0001.jpg (35.77 KiB) Viewed 726 times
Lang's used to sell that part as Lang's # PBEDAD, but no longer avail, these were made by Howells a few years ago.
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Fri Oct 24, 2025 4:10 pm
You should do your homework.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Fri Oct 24, 2025 7:20 pm
uhmmmmmmm Hey Moe Hey Larry.......,,,,,, Ouch..., Ouch...., Stop It!
TA Man
Last Name: Partain
Post by TA Man » Sat Oct 25, 2025 12:08 am
Hey guys, thanks for the info on the pan, the photos are great and part number too.
It's my understanding that the pan is kind of humped up in the middle between the strips, where the Model A pan is all flat across the top. I'm guessing that the rear crossmember needed just a little more clearance under the pan on the T than on the A.
I may see if I can get the drawing for this from the Benson Archives.
Does anyone have a photo of the top profile showing the hump?
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Sat Oct 25, 2025 6:00 am
There are three photos in this recent thread of it installed correctly.
https://mtfca.com/phpBB3/viewtopic.php?f=2&t=49974
Vern (Vieux Carre)
TA Man
Last Name: Partain
Post by TA Man » Sat Oct 25, 2025 11:56 am
Thankyou for the link to that thread!
