Model T Vintage Screwdriver
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Sun Oct 26, 2025 11:28 pm
What year did Ford change from the SQUARE shank to the ROUND shank screwdriver in tool kits?
Re: Model T Vintage Screwdriver
Post by Allan » Mon Oct 27, 2025 1:40 am
It may be that there was a gap between the square shank and the round shank, filled by the screwdriver tip ground onto one of the pliers handles during T production. I believe the round shank came with the A model screwdriver. it too went right through the wooden handle just as the T one did.
US production may be different to the Canadian stuff with which I am familiar.
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Mon Oct 27, 2025 6:24 am
There was no round shank Model T screwdriver.
George Mills
Last Name: Mills
Post by George Mills » Mon Oct 27, 2025 1:05 pm
Terry,
I have never uncovered anything that would suggest T1902 was other than square shank all the way up until it was no longer in use being obsoleted in Oct 20.
There is no record of a T number ever being issued for anything else and 3z and 5z shop tool issues are always a tough act to follow and make sense of when an item is not stamped!
Post by Scott_Conger » Mon Oct 27, 2025 3:36 pm
Tractor, "A", and V-8 screwdrivers are all round shank. I own one of them and it is stamped "FORD" on the wood, having been placed (I believe) post manufacture for perhaps identification in someone's tool box at the factory or Agency...I say that because it is an identical stamp as is occasionally found on tools obviously non-Ford in nature and in my opinion, were generally regarded as generic tools used in the factory or agency for non-assembly tasks.
Post by Allan » Mon Oct 27, 2025 10:21 pm
Years ago I bought a used round shank screwdriver that had been used often as a paint stirer. The shank does not go through the handle like an A model one. It did have a nice wooden handle, so I bought it to go in a T tool roll, even though it was not "correct". Imagine my surprise when wire buffing the paint off the shaft revealed a perfect Ford script stamped into the shaft!
