New float, viton tipped needle and seat conversion, new choke spring, reconditioned spray needle, throttle shaft bushing installed.
The original throttle arm/shaft and petcock were missing so I used a modified Holley G throttle shaft and Kingston L2 drain valve.
$400 postpaid to continental USA email: wlkma9@gmail.com
Kingston 4 ball carburetor/sold
Corey Walker
Topic author - Posts: 682
- First Name: Corey
- Last Name: Walker
Corey Walker
- First Name: Corey
- Last Name: Walker
Re: Kingston 4 ball carburetor
Pictured is the Holley throttle arm on the left and an original Kingston on the right. Not a noticeable difference and the staple instead of 2 screws to secure the plate aren’t visible once installed.
- Attachments
- IMG_9622.jpeg (46.17 KiB) Viewed 411 times
- IMG_9624.jpeg (103.54 KiB) Viewed 411 times
- IMG_9618.jpeg (91.06 KiB) Viewed 411 times
Corey Walker
- First Name: Corey
- Last Name: Walker
