Smith form a truck.
Bob Pilkie
Topic author - Posts: 56
- First Name: Bob
- Last Name: Pilkie
- * REQUIRED* Type and Year of Model Ts owned: TT trucks and speedsters.
Smith form a truck.
Hi I recently found a smith form a truck but it seems to have been made for a larger car than a model T. Does anyone have info on them. Did they make different models for other brands of cars. All I can find is the ones for model Ts.
Re: Smith form a truck.
There were such devices which could be fitted to TT's to turn them into 2TT's. I do not know if Smith form-a-trucks made these. The 2TT I worked on had eliptical springs on the rear axle, an auxiliary transmission and a jack shaft to make the connection to the worm drive torque tube.
Bob Pilkie
- First Name: Bob
- Last Name: Pilkie
Hi Alan. I have one of those kits on a TT truck also. It’s made by Olson it’s a neat setup. Yes it has elliptical springs. And the wheelbase is longer by the length of the warford transmission. And the frame goes back past the rear wheels about 3 feet.
- First Name: Adrian
- Last Name: Whiteman
Hi Bob, I would be interested to see a picture of your 2TT setup if you could post a picture here
Thanks Adrian
Thanks Adrian
Smith Form-a-truck kits were available for any car to convert to a truck, but as most cars of the time were T's, the form-a-truck became most associated with the Ford.
Period advertising for them listed Ford, Maxwell and Chevrolet with a $350 kit.
Before they began building exclusively for the Dodge Brothers (1920ish?), in the mid 1910s, The Graham Brothers manufactured make a truck kits to fit basically any automobile. Their advertising targeted mostly non-Fords, although they did also make kits for the model T. Their kits were mostly custom built, tell them what chassis you had and what you wanted it to be capable of hauling, and they would build the kit to fit your needs. As a matter of record, they did make a kit for a Stutz as well as the more common Cadillac and Hudson cars.
Bob Pilkie
- First Name: Bob
- Last Name: Pilkie
How do I add a picture here of my smith form a truck kit
Hi Bob, this post covers the process: https://mtfca.com/phpBB3/viewtopic.php?f=9&t=45439
Bob Pilkie
- First Name: Bob
- Last Name: Pilkie
Does anyone have a smith form a truck attached to a car other than a model T.
