Need help with Rux lft side shifter
Topic author - Posts: 179
- Last Name: Willams
- * REQUIRED* Type and Year of Model Ts owned: '09 Roadstr, '12 Touring, '26 Fronti Speedster
Hi From Hot In Iowa! I purchased a new left side Ruxtel shifter from one of the major suppliers last year and today when I unpacked to put it on my T I found that they had forgotten to supply an instruction sheet to at least give suggestions as to how to install it! I just can't make sense as to where to begin with it all? Can anyone tell me how to begin or where to find some printed instructions! I would really appreciate some help with this! I am also installing the Hydralic Brake set up & it came with very detailed instructions that are not only informative , but are easy to understand & follow! Many Thanks Joyhn
Re: Need help with Rux lft side shifter
Hi From Iowa! Thanks Again To All you Great Model Ters! You have provided the Exact Info I needed To understand How to go about installing the left side shifter!!! John
Put the stock one in, and forget the left side b.s!
- First Name: Bob
- Last Name: Middleton
- * REQUIRED* Type and Year of Model Ts owned: 18 roadster 1810 brand X
Search the forum earlier i post how i made mine out of a worn out hand brake assembly
I couldbuse the same hole as e brake but i made it longer
