Model T 6v Starter Field Coils Kit - Brand New
Jeff
First Name: Jeff
Last Name: Stevenson
* REQUIRED* Type and Year of Model Ts owned: 1921 Touring
Post by Jeff » Sat Nov 08, 2025 12:53 pm
Brand New 6 Volt Model T Starter Field Coils and everything needed to install them.
$59 + shipping (usually under $10) - Compare at OVER $100 for the Wilsons
These are also Epoxy dipped with plastic insulators between the fields and will likely last well over 100 years.
Note - the post is Silver Soldered and pre-installed
starter field coil.jpeg (103.55 KiB) Viewed 362 times
"The trick to creativity is knowing how to hide your sources..." Albert Einstein
1921 Model T Touring, 1930 Model A Roadster
Voltage Regulators, Starter & Generator Repair & Parts manufacturing
www.modeltregulators.com
www.modeltstarters.com
