Patina in a can
NHUSA
First Name: Fred
Last Name: Dimock
* REQUIRED* Type and Year of Model Ts owned: 1919 T with Mifflinburg Suburban body
Patina in a can
Post by NHUSA » Sun Nov 09, 2025 9:16 am
A guy is selling a wipe on patina in a can for about $160 per quart.
It is suposed to bring back the shine, protect the rusty surface, and remaining finish from further damage.
Is this stuff really worth it?
Linseed oil?
NH - Where I used to live - not the carburetor ! :lol:
love2T's
First Name: T
Last Name: Gates
Re: Patina in a can
Post by love2T's » Sun Nov 09, 2025 10:04 am
Product name might help but at that price it ought jump outa the can and DO THE WORK for ya!! :lol:
There's some crap, yes crap, called Nevr Dull or something like that, that just plain is junk. I may still have the can of it somewhere that I'll give away! :lol:
Adam
First Name: Adam
Last Name: Doleshal
Re: Patina in a can
Post by Adam » Sun Nov 09, 2025 10:21 am
Linseed oil?
Here is what some of the the railroad museums have been using to restore old paint that is “chaulked-out” and deteriorated. It brings back the color and a nice gloss/semi-gloss. Plus it adds a layer of protection over bare metal and rust. They just brush it on straight out of the can. I would bet that if the two products were tested side by side, they might be extremely similar…
The Penetrol is only $13 to $18 for a quart depending on where you buy it. It’s available at many hardware & home improvement stores.
George Mills
Last Name: Mills
Re: Patina in a can
Post by George Mills » Sun Nov 09, 2025 12:44 pm
Fred,
I use something called OSPHO. it Likes slightly oxidized surfaces and converts that rust dust to something inert and dull black. It's one of those rubber glove things so ya have to be careful...and if left exposed once neutralized will again slowly rust... I mention it because my finish for everything not painted is pretty much linseed oil if I can coat it and hang it long enough to fully dry and you mentioned linseed oil :)
NHUSA
First Name: Fred
Last Name: Dimock
Re: Patina in a can
Post by NHUSA » Sun Nov 09, 2025 12:54 pm
The stuff is called Poppy’s Patina.
Mike Silbert
Last Name: Silbert
Re: Patina in a can
Post by Mike Silbert » Sun Nov 09, 2025 9:03 pm
Here is what I have used on different occasions on different surfaces
Rust-Oleum 1 qt. Clear Varathane Oil-Based Exterior Spar Urethane, Satin
https://www.tractorsupply.com/tsc/produ ... in-2344764
Rust-Oleum 1 qt. Clear Varathane Oil-Based Exterior Spar Urethane, Gloss
https://www.tractorsupply.com/tsc/produ ... hane-gloss
Clear, Rust-Oleum Marine Coatings Gloss Spar Varnish-207008, 1 qt
https://www.walmart.com/ip/Clear-Rust-O ... t/52500347
And if it is a loose surface that I can not clean well
Zinsser Peel Stop Clear Water-Based Bonding Primer 1 qt
https://www.acehardware.com/departments ... rs/1371087
All of these are clear or slightly milky finishes that hold up well and do not need another coat for many years.
I like natural (barn fresh) looking cars so I leave them as is when/where possible and just drive them.
Mike
dykker5502
First Name: Michael
Last Name: Deichmann
Re: Patina in a can
Post by dykker5502 » Mon Nov 10, 2025 4:08 am
Here is their webshop: https://poppyspatina.com/
Ford Model T 1914 Touring
