ISO Switch
Todd Touchberry
First Name: Todd
Last Name: Touchberry
* REQUIRED* Type and Year of Model Ts owned: 1919. And 1920
ISO Switch
Post by Todd Touchberry » Thu Nov 13, 2025 2:33 pm
I'm about to start a frame up build and am need of a good ignition switch and key.
Let me know what you have.
Thanks Todd Touchberry
Todd Touchberry
Tim D
Last Name: Dickson
* REQUIRED* Type and Year of Model Ts owned: 1912 speedster 1911 Torepdo
Re: ISO Switch
Post by Tim D » Thu Nov 13, 2025 3:15 pm
What year are you looking for? i have a repop for a 26-7
Re: ISO Switch
Post by RajoRacer » Thu Nov 13, 2025 3:25 pm
I have some earlier - need an ammeter ?
Runabout
Last Name: McClelland
* REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1911 Mother-n-law roadster, 1919 Coupe, 1920 Depothack, 1922 Centerdoor, 1923 Roadster, 1923 Speedster, 1924 TT Truck,
Re: ISO Switch
Post by Runabout » Thu Nov 13, 2025 6:37 pm
I’ve got this new one if interested let me know $250 shipped.
Re: ISO Switch
Post by speedytinc » Thu Nov 13, 2025 6:41 pm
That covers the whole range from 14-27.
You can see, you need to specify which one you want.
Todd Touchberry
First Name: Todd
Re: ISO Switch
Post by Todd Touchberry » Fri Nov 14, 2025 11:54 am
1920 0r so. It's for a speedster build and yes I'll need an amp meter.
Todd Touchberry
Re: ISO Switch
Post by TRDxB2 » Fri Nov 14, 2025 1:17 pm
Just a suggestion. Since speedsters often brake the rules of authenticity it sounds like your making your own dash panel. If your exposing the Coil Box a switch on it may be the way to go. If your dash is to look like a "racer" several gauges (amp, volts, speedometer, etc) you may just get an accessory switch with ON, BAT, MAG (will you have MAG)
Shannon_in_Texas
First Name: Shannon
Last Name: Helm
Re: ISO Switch
Post by Shannon_in_Texas » Fri Nov 14, 2025 1:22 pm
Frank, that is very racy-looking in a speedster kind of way!
Todd Touchberry
First Name: Todd
Re: ISO Switch
Post by Todd Touchberry » Mon Nov 17, 2025 9:49 pm
Where might one find one of those switches?
Todd Touchberry
Re: ISO Switch
Post by TRDxB2 » Tue Nov 18, 2025 10:57 am
You might search eBay. Need to be careful though, some too pricey, pot metal handle, missing key...
Another option is an early 1926 -27 switch. These had no reinforcing indents (I have some.) See diff
The dash I have is from a 1926 Dodge.
If your lucky you might find one like this for $75 :shock: That shape is similar to the early 1926 switch
Todd Touchberry
First Name: Todd
Re: ISO Switch
Post by Todd Touchberry » Wed Nov 19, 2025 2:15 pm
Yeah. 750.00 is a tad high. lol
Todd Touchberry
