Replairing Outside Door Handle on 26-27
ModelTWoods
Topic author - Posts: 1578
- First Name: Terry
- Last Name: Woods
I have an improved car outside door handle with a broken, rusted spring behind the escutcheon plate. Taking it apart to replace the broken spring was easy, I just had to grind/file the crimped shoulders behind the spring retainer to remove the retainers and the broken spring from the square shaft. Putting it together is easy until it comes to crimping the square shaft behind the spring retainer so everything stays in place. I do not have access to a press or a heat torch to help make the crimps, and trying to hold the square shaft in a bench vise while smacking a chisel with a mechanics ball peen hammer, is almost impossible (I tried). anyone got any suggestions?
ModelTWoods
- First Name: Terry
- Last Name: Woods
Mike Silbert
- First Name: Mike
- Last Name: Silbert
Re: Replairing Outside Door Handle on 26-27
Is there a club member near you that can help?
Someone in your local chapter?
I would fix it no charge for you, but I am 1600 miles away.
Helping each other is one of the benefits of the club.
Mike
Mike
varmint
- First Name: Vernon
- Last Name: Worley
I'm 542 miles on I-10 and would do it for free.
Maybe someone's closer.
Vern (Vieux Carre)
Can you post a photo of the area of concern?ModelTWoods wrote: ↑Mon Nov 17, 2025 5:44 pmI have an improved car outside door handle with a broken, rusted spring behind the escutcheon plate. Taking it apart to replace the broken spring was easy, I just had to grind/file the crimped shoulders behind the spring retainer to remove the retainers and the broken spring from the square shaft. Putting it together is easy until it comes to crimping the square shaft behind the spring retainer so everything stays in place. I do not have access to a press or a heat torch to help make the crimps, and trying to hold the square shaft in a bench vise while smacking a chisel with a mechanics ball peen hammer, is almost impossible (I tried). anyone got any suggestions?
ModelTWoods
- First Name: Terry
- Last Name: Woods
Jerry, I'm not sure what good posting a picture of the handle will do, but here you go. The square shaft was originally crimped in the area where the vise grips are attached holding the spring and retainer in proper place. One small bead of weld on two opposite sides of the shaft would also hold things in place. A local club member has done welding for me in the past, But I feel guilty asking him for so many favors.Jerry VanOoteghem wrote: ↑Tue Nov 18, 2025 10:36 amCan you post a photo of the area of concern?ModelTWoods wrote: ↑Mon Nov 17, 2025 5:44 pmI have an improved car outside door handle with a broken, rusted spring behind the escutcheon plate. Taking it apart to replace the broken spring was easy, I just had to grind/file the crimped shoulders behind the spring retainer to remove the retainers and the broken spring from the square shaft. Putting it together is easy until it comes to crimping the square shaft behind the spring retainer so everything stays in place. I do not have access to a press or a heat torch to help make the crimps, and trying to hold the square shaft in a bench vise while smacking a chisel with a mechanics ball peen hammer, is almost impossible (I tried). anyone got any suggestions?
Terry,ModelTWoods wrote: ↑Tue Nov 18, 2025 6:19 pmJerry, I'm not sure what good posting a picture of the handle will do, but here you go. The square shaft was originally crimped in the area where the vise grips are attached holding the spring and retainer in proper place. One small bead of weld on two opposite sides of the shaft would also hold things in place. A local club member has done welding for me in the past, But I feel guilty asking him for so many favors.Jerry VanOoteghem wrote: ↑Tue Nov 18, 2025 10:36 amCan you post a photo of the area of concern?ModelTWoods wrote: ↑Mon Nov 17, 2025 5:44 pmI have an improved car outside door handle with a broken, rusted spring behind the escutcheon plate. Taking it apart to replace the broken spring was easy, I just had to grind/file the crimped shoulders behind the spring retainer to remove the retainers and the broken spring from the square shaft. Putting it together is easy until it comes to crimping the square shaft behind the spring retainer so everything stays in place. I do not have access to a press or a heat torch to help make the crimps, and trying to hold the square shaft in a bench vise while smacking a chisel with a mechanics ball peen hammer, is almost impossible (I tried). anyone got any suggestions?
I thought that a photo might help to suggest an alternate method of fixing the retainer in place. If you feel it wouldn't help, then you can skip it. No problem.
ModelTWoods
- First Name: Terry
- Last Name: Woods
Jerry, I've tried resizing the picture that I took with my cell phone, so many times that I'm now cross eyed. I give up. Sorry, can't post picture.Jerry VanOoteghem wrote: ↑Tue Nov 18, 2025 6:39 pmTerry,ModelTWoods wrote: ↑Tue Nov 18, 2025 6:19 pmJerry, I'm not sure what good posting a picture of the handle will do, but here you go. The square shaft was originally crimped in the area where the vise grips are attached holding the spring and retainer in proper place. One small bead of weld on two opposite sides of the shaft would also hold things in place. A local club member has done welding for me in the past, But I feel guilty asking him for so many favors.
I thought that a photo might help to suggest an alternate method of fixing the retainer in place. If you feel it wouldn't help, then you can skip it. No problem.![]()
Terry,ModelTWoods wrote: ↑Tue Nov 18, 2025 8:28 pmJerry, I've tried resizing the picture that I took with my cell phone, so many times that I'm now cross eyed. I give up. Sorry, can't post picture.Jerry VanOoteghem wrote: ↑Tue Nov 18, 2025 6:39 pmTerry,ModelTWoods wrote: ↑Tue Nov 18, 2025 6:19 pm
No problem. Is there enough room in there to drill a very small hole and install a tiny roll pin or dowel? Obviously, nothing large enough to weaken the shaft.
ModelTWoods
- First Name: Terry
- Last Name: Woods
Jerry, that's a good idea, but the square shaft is only 1/4" square, and any drilled hole larger than 1/16" would probably weaken the shaft to the point durability would probably become a problem.Jerry VanOoteghem wrote: ↑Wed Nov 19, 2025 6:28 amTerry,ModelTWoods wrote: ↑Tue Nov 18, 2025 8:28 pmJerry, I've tried resizing the picture that I took with my cell phone, so many times that I'm now cross eyed. I give up. Sorry, can't post picture.Jerry VanOoteghem wrote: ↑Tue Nov 18, 2025 6:39 pm
Terry,
A 1/16" or smaller hole is what I had in mind.ModelTWoods wrote: ↑Wed Nov 19, 2025 3:34 pmJerry, that's a good idea, but the square shaft is only 1/4" square, and any drilled hole larger than 1/16" would probably weaken the shaft to the point durability would probably become a problem.Jerry VanOoteghem wrote: ↑Wed Nov 19, 2025 6:28 amTerry,ModelTWoods wrote: ↑Tue Nov 18, 2025 8:28 pm
