FS Winfield Carburetor Adapter
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Sat Nov 22, 2025 4:41 pm
Original Winfield carburetor adaptor. Cast aluminum, with S-63 numbers cast into it. Has a threaded hole for fuel primer or brass plug. Measures 1-5/8 between center of holes on square mounting side. 2-11/16 between center of holes on manifold mounting side. 1-7/16 x 1-1/2 diameter taper in bore. 1-1/2 opening on square side. 75.00 includes shipping.
