F/S RM ? Large drum brake set up
First Name: craig
Last Name: leach
Post by Craig Leach » Sun Nov 23, 2025 10:29 pm
I ran across these that an old friend had & his widow would like to sell them They are RM bands & hardware with flame cut mounts & improvised equalizer for what appears to be large drum brake setup there are no drums but the rest seems to be there. Everything appears to be new. If
anyone knows more about them we would like to know. I would think they should be worth at least $500
the rods are there also.
Looks like USPS will ship for under $50
Re: F/S RM ? brake set up
Post by RajoRacer » Mon Nov 24, 2025 10:52 am
Seeing how the 2 rear mounting tabs utilize small bolts, it's most likely a set for a large drum set up - one has to drill out those 2 rivets from the large drum backing plate.
First Name: craig
Last Name: leach
Post by Craig Leach » Mon Nov 24, 2025 2:02 pm
Good observation Steve I was going by the diameter which is hard to do without a drum.
Post by RajoRacer » Mon Nov 24, 2025 2:04 pm
Small drum brake rear spring bars both attach to the rear brake anchor bolt.
First Name: craig
Last Name: leach
Post by Craig Leach » Sun Dec 14, 2025 1:15 am
Please move to top. Thanks
First Name: craig
Last Name: leach
Re: F/S RM ? Large drum brake set up
Post by Craig Leach » Mon Dec 22, 2025 6:51 pm
Lets try this one more time before I return them to the owner.
