Old Horn for my T
BillM
Topic author - Posts: 35
- First Name: BILL
- Last Name: MAULDIN
- * REQUIRED* Type and Year of Model Ts owned: 1923 Coupe
Old Horn for my T
Would this horn be appropriate for my 23 coupe?
- First Name: Keith
- Last Name: Townsend
Re: Old Horn for my T
It is from the era, but not a stock Model T horn.
As long as your T is 6v and is wired for a battery horn, it would probably work just fine.
Only you can decide what is "appropriate" for your car.
BillM
- First Name: BILL
Ok thanks for the reply KW!
ModelTWoods
- First Name: Terry
- Last Name: Woods
Most Klaxon horns were motor driven. Ford T horns were vibrator.
That one is the Model 20, made in versions for big cars, cycles and boats.
The best length of the projector and horn body that helps to fit under the hood, is found on the small Klaxon 6, that is the Ford T size.
