Are you in Winfield?
Post by Steve Jelf » Mon Dec 01, 2025 2:48 pm
Here I am in the old folks' home, without a T. I haven't hand-started an old car since September 7, 2023. I've been wondering if I'm now physically up to the task. Probably so, but it would be nice to give it a try and see if I can still crank-start. Does anybody on the forum have a running T near or in Winfield, KS, that I could try to start? If so, contact me through the forum, and we can pick a date and time of day.
First Name: Henry
Last Name: Lee
Re: Are you in Winfield?
Post by Henry K. Lee » Mon Dec 01, 2025 4:40 pm
Who is paying for rehab and your deductible if you hurt yourself? Asking for a friend.
Daisy Mae
First Name: Kurt
Last Name: Andersson
Board Member Since: 2024
Post by Daisy Mae » Mon Dec 01, 2025 5:29 pm
That there is just pure love for the T...
I hope to keep cranking my '14 for years to come, but with the rebuild this year I'm adding a ringed flywheel and starter mag in case I ever need to swap out to a hogshead w/starter
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Mon Dec 01, 2025 7:11 pm
Steve,
When my starter was out some time ago, you sent me a link of you hand cranking your Model T. I can still see it in my mind.
Thanks,
Vernon
Vern (Vieux Carre)
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Mon Dec 01, 2025 8:57 pm
Aussie16
First Name: Warwick
Last Name: Landy
Post by Aussie16 » Tue Dec 02, 2025 5:10 am
If I were closer, Id find a T,pick you up and do a road trip to the Old Car Festival with you! Hopefully someone can swing this for you? Good luck with your quest to crank a T again.
Virtus
First Name: Paul
Last Name: Robertson
* REQUIRED* Type and Year of Model Ts owned: Ford model tt 1921 right hand drive
Post by Virtus » Sun Dec 07, 2025 4:54 am
No takers for Steve's request! A chance to chat with one of the major contributors to these columns by giving him the chance to swing over a T one more time. Unfortunately I'm in the U.K. and unable to help. Good luck Steve and thank you for all the information and entertainment in your blog.
Post by Steve Jelf » Sun Dec 07, 2025 12:22 pm
UPDATE: We've got it covered. I've received a call from a T owner who lives a couple of miles from me. We'll be getting together for a bit of starting practice. :)
Post by TXGOAT2 » Sun Dec 07, 2025 2:03 pm
Good news.... I hope you have fine weather.
Last Name: Hjortnaes
Post by DHort » Sun Dec 07, 2025 11:31 pm
I think someone should bring a T to the Winter Clinic and Steve starting it there will be one of the presentations.
Post by Steve Jelf » Thu Dec 11, 2025 10:56 pm
Today was it. Steve Behrendt brought his 1925 and we found that I can still pull a crank and start a car.
Starting on BAT is still easy. I tried several pulls on MAG, and it was a no-go every time. I don't know if that was because of me, or a weak magneto. But the car ran on MAG with no trouble at all.
It was a bit of a surprise that with many years and thousands of miles of Model T driving, two years without any have made me a little rusty. I was able to drive a little, but I felt like a beginner.
Post by DHort » Fri Dec 12, 2025 2:03 am
ATTABOY!!!
Virtus
First Name: Paul
Post by Virtus » Fri Dec 12, 2025 4:26 am
Well done Steve!
South Park Zephyr
Last Name: Francis
Board Member Since: 2022
Post by South Park Zephyr » Fri Dec 12, 2025 8:30 am
It is wonderful to see you behind the wheel again
Scott
aDave
First Name: David
Last Name: Dufault
Post by aDave » Fri Dec 12, 2025 9:26 am
Post by TXGOAT2 » Fri Dec 12, 2025 9:30 am
My car starts easier on battery if it has sat overnight. For the rest of the day, it starts as easily on magneto. I'm not sure why since for most of the summer the car is already half warmed up from the ambient heat.
George Mills
Last Name: Mills
Post by George Mills » Fri Dec 12, 2025 2:42 pm
Kudos Steve J. Thank you Steve B !!!!
First Name: Austin
Last Name: Farmer
Post by 1925 Touring » Fri Dec 12, 2025 10:45 pm
Great to hear!
Congratulations!
RGould1910
Last Name: Gould
Post by RGould1910 » Wed Dec 17, 2025 5:54 pm
Way to go, Steve!!
Keep it up!
Sean Butler
First Name: Sean
Last Name: Butler
Post by Sean Butler » Thu Dec 18, 2025 12:02 pm
Good to see, Steve!
Sean Butler
Huntington Beach, CA
Cody Winters
First Name: David
Last Name: Winters
Board Member Since: 2023
Post by Cody Winters » Mon Dec 22, 2025 4:32 pm
Fantastic to see you still have it!
keep up the good work Steve!
