Driving plate rivets dimensions?
Dave1
Last Name: Eddie
* REQUIRED* Type and Year of Model Ts owned: 1926 Tudor, 1926 Touring, 1931 Plymouth PA, 1952 Hudson Hornet
Post by Dave1 » Mon Dec 01, 2025 11:22 pm
What are size of the replacement driving plate rivets for a 26?
I have some on hand that “ I believe “ are the right size?
Truth be told I ordered some a couple of years back,
Used what I needed ,….. then lost the packaging !
jab35
Last Name: Bartsch
Re: Driving plate rivets dimensions?
Post by jab35 » Tue Dec 02, 2025 4:12 pm
Dave1
Last Name: Eddie
Post by Dave1 » Tue Dec 02, 2025 9:28 pm
Thank you.
J and M Machine
Last Name: Gulbankian
Post by J and M Machine » Sat Dec 06, 2025 9:19 am
If the rivets are loose I would recommend you check the plate for cracks as they crack between rivets.
Last Name: Hatch
Post by Dan Hatch » Sat Dec 06, 2025 9:35 am
Having found many, many driven plates cracked I have wondered if they could be repaired. Has anyone ever tried using the Loc n Stitch method to repair one?
How about welding? Or any other method? Dan
Post by speedytinc » Sat Dec 06, 2025 12:01 pm
I have seen these drive plates with 3 1" welds between the shaft flange & plate.
I like the added rigidity. Those few cracks become irrelevant.
Used drive plates are still plentiful enough @ swap meets for $10.
