Question about the Mounting hardware for 26-27 headlights
Reno Speedster
First Name: Morgan
Last Name: Blanchard
* REQUIRED* Type and Year of Model Ts owned: 1926 Model T Speedster Project, 1922 Runabout Pickup
Post by Reno Speedster » Sun Dec 07, 2025 2:19 am
I am working on light mounts for my 26 speedster. I don’t have the mounting hardware. The critical part as I understand it is a washer with a convex top that matches the concave shape on the lamp itself. Can anyone post a picture of the washer, tell me how big around it is, and tell me the diameter of the bolt that goes through it?
Last Name: Hatch
Re: Question about the Mounting hardware for 26-27 headlights
Post by Dan Hatch » Sun Dec 07, 2025 5:38 am
Is it the same washer as the one on the muffler?
Post by DanTreace » Sun Dec 07, 2025 10:31 am
The T-6509X headlamp bracket conical washer should fit the radius of the T-6517X '26-'27 headlamp tie rod and bracket.
Here are the mounting pieces.
The conical washer goes under the bracket to allow the swivel action. Don’t heavily paint as the lamp needs ground thru the bracket to the fender and then to the frame.
IMG_2393 (501x535).jpg (143.29 KiB) Viewed 491 times
jab35
Last Name: Bartsch
Post by jab35 » Sun Dec 07, 2025 11:12 am
Mounting kit reproduction is available.
https://www.modeltford.com/item/6504X.aspx
Reno Speedster
First Name: Morgan
Post by Reno Speedster » Sun Dec 07, 2025 11:50 am
Perfect, thanks!
