Found a 26-27 headlight. Thanks
Reno Speedster
First Name: Morgan
Last Name: Blanchard
* REQUIRED* Type and Year of Model Ts owned: 1926 Model T Speedster Project, 1922 Runabout Pickup
Post by Reno Speedster » Sun Dec 07, 2025 9:13 pm
I am looking for a decent 1926-1927 headlight. Let me know what you have and need for it.
Last edited by Reno Speedster on Mon Dec 08, 2025 11:09 am, edited 2 times in total.
Mike Silbert
Last Name: Silbert
Re: WTB 1926 -27 Headlight
Post by Mike Silbert » Sun Dec 07, 2025 10:55 pm
Which style do you want?
"1926" style that mounts to the fender
or
"1927" style that mounts to the headlight bar
Pictures from the MTFCA Encyclopedia web pages
Post by Allan » Sun Dec 07, 2025 11:30 pm
The earlier type also comes in Left and right side applications.
Reno Speedster
First Name: Morgan
Post by Reno Speedster » Mon Dec 08, 2025 12:40 am
Thanks Allan, I am looking for the later one mounted on the fender tie rod.
MotoBrew
Last Name: Schmidt
* REQUIRED* Type and Year of Model Ts owned: Runabout 1927
Post by MotoBrew » Mon Dec 08, 2025 9:15 am
Langs has them. I had to replace one on my 27. https://www.modeltford.com/item/6512.aspx
They also have a rebuilding kis in chrome and nickel. I used one of the nickel ones. It is a good kit but required me to slightly reduce the outer diameter of the reflector to get it to fit properly onto the head light bucket. I compared the original reflector to the replacement and the replacement was definitely slightly larger in outer dia. This caused it to not fit/seat correctly into the bucket. Once I sanded down the OD of the replacement it fit just fine.
New Caretaker of my Grandfathers Model T. Learning how to maintenance it, keep it running and fun drives around the New England Seacoast. Not new to working on cars and motorcycles, but definitely learning the unique things that the Model T has. It is a fun journey and am thankful to have a community like the one here to help. Cheers, Steve
