FS cowl gas tank
Karl Von Neumann
First Name: Karl
Last Name: VonNeumann
Board Member Since: 2022
FS cowl gas tank
Post by Karl Von Neumann » Thu Dec 11, 2025 9:24 am
Cowl gas tank does not leak solder has been touched up round the outlet. Over flow tube is broken off at the outlet Decent looking usable tank $200 plus the ride or local pick up pleasant prairie wisconsin can sell you the straps for an additional 50$
Karl Von Neumann
First Name: Karl
Re: FS cowl gas tank
Post by Karl Von Neumann » Thu Dec 18, 2025 12:09 pm
Move to top
Karl Von Neumann
First Name: Karl
Post by Karl Von Neumann » Wed Jan 14, 2026 10:04 am
Move to top
schwabd1
First Name: David
Last Name: Schwab
Post by schwabd1 » Thu Jan 15, 2026 10:28 pm
Is this an open car or closed car tank?
Karl Von Neumann
First Name: Karl
Post by Karl Von Neumann » Fri Jan 16, 2026 11:36 am
26 27 is all the same goes under the cowl
Post by TXGOAT2 » Fri Jan 16, 2026 11:41 am
Isn't the four door closed car tank on the 26-27 under the seat?
Karl Von Neumann
First Name: Karl
Post by Karl Von Neumann » Fri Jan 16, 2026 11:45 am
Yes! I was just thinking about that the 4 door is under the seat thebrest are cowl mount
schwabd1
First Name: David
Last Name: Schwab
Post by schwabd1 » Sat Jan 17, 2026 9:46 am
I always thought they were the same, but doing a little research led me to information the open cars were a little shorter and the radius was different. A note on the VowellArt illustration also notes this and advises they cannot be interchanged.
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Sat Jan 17, 2026 10:40 am
The 26-27 Cowl tank fits the Roadster, Touring, Coupe, and 2dr sedan.
The TT Truck, Car Chassis, and Fordor kept the Oval Tank of previous years.
The Fordor sedan body was just a modified cowl with general improvements body that was introduced in 1923.
These were still made by outside suppliers and have lots of variances and improvements over the years.
The differences between the years and makers could fill pages of print.
That said, the "1926" and "1927" cowl tanks are different in the outlet fitting casting, overflow tube, and where the overflow lock screw is located.
The screw was moved to make assembly easier coming down the production line.
It is a subtle change and not usually noticed, the whole tank and overflow tube assembly interchange.
Model T parts are a rolling evolution of improvements through the years.
For every "rule" there is at least one exception.
Mike
Post by TXGOAT2 » Sat Jan 17, 2026 11:27 am
I don't think any two of them were actually 100% identical, contrary to the legend.
