floor board risers
Tinner12
First Name: Vernon
Last Name: Enis
* REQUIRED* Type and Year of Model Ts owned: 1917 and 1924 touring,1926 4 door
Board Member Since: 2011
floor board risers
Post by Tinner12 » Tue Dec 16, 2025 2:43 pm
Can anyone tell me what model these are for
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Re: floor board risers
Post by Rich P. Bingham » Tue Dec 16, 2025 5:48 pm
Touring car or runabout, hard to put a date on them, at one point Ford jobbed bodies from several coach builders. They would be pretty much the same from 1915-25 although some of the earlier ones used wood members.
Get a horse !
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Wed Dec 17, 2025 1:04 am
I will take a stab at these:
In 1915 open cars these were made of wood which was used for many years until they changed to metal ones like in the picture.
These are used in a car with wood sill rails and wood body posts because of the screw holes.
For the "improved" 1926 open cars the floorboard risers were made differently for the "All Steel" body.
I don't know when the wood to metal changeover was, so I say this is for '20 or '21 to '25 open cars.
Now closed cars were slower to make the transition from wood to metal and continued to use wood structure in the bodies of the Fordor through 1927
The coupe and Tudor went to "All Steel" for the 1926 year.
I am not familiar with the wood structure closed cars to tell if this fits the '20s closed cars.
A restorer of closed cars would have to answer if that fits.
Plankhill
First Name: Brendan
Last Name: Doughty
* REQUIRED* Type and Year of Model Ts owned: 16 , 21, 24, Touring , 24 Roadster, 26 Speedster
Post by Plankhill » Wed Dec 17, 2025 4:16 pm
1925 is not the same as these.
Will_Vanderburg
First Name: William
Last Name: Vanderburg
Post by Will_Vanderburg » Wed Dec 17, 2025 5:29 pm
I believe the ones for 25 are riveted to the firewall.
William L Vanderburg
1922 Center Door Sedan
Post by DanTreace » Wed Dec 17, 2025 6:10 pm
Here is older post showing coupe and open car metal risers. The ‘25 open car risers have tabs to secure the kick panel, earlier metal risers the kick cardboard panel is shaped to the curve by tacks to the wood framing.
Order posts shows types:
https://share.google/UYhmO246sxXE3RWKx
