26 touring seat height
Dave1
Last Name: Eddie
* REQUIRED* Type and Year of Model Ts owned: 1926 Tudor, 1926 Touring, 1931 Plymouth PA, 1952 Hudson Hornet
Post by Dave1 » Wed Dec 17, 2025 2:46 pm
I have a 26 touring that I acquired a couple of years ago.
Prior to me buying it had been restored, as in paint, body work and upholstery.
The seat height is too high, with the top up you have to duck your head to see through the windshield, annoying !
It appears that the seat springs have been replaced, no doubt a product from the T parts suppliers.
Wondering if anyone else has come across this issue, and what is the remedy?
Moxie26
Last Name: Jablonski
Re: 26 touring seat height
Post by Moxie26 » Wed Dec 17, 2025 4:02 pm
Let's face it, people back then were shorter than what we are now. Height was in the range of 5'2 to maybe 5'5... And Ford made his cars accordingly to fit into people that would purchase.
Dave1
Last Name: Eddie
Post by Dave1 » Wed Dec 17, 2025 4:26 pm
Granted, however if I sit in a car with OEM springs the seat
“ sags “ with your weight on it, this is too hard
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Wed Dec 17, 2025 4:27 pm
Making a softer and lower cushion and making a less bulky back rest are a remedy but it is really depended about your stature. Taking about 4" of the steering column for folks with a larger waist is another remedy.
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Wed Dec 17, 2025 7:05 pm
Dave,
I have a stock 1926 touring and the front cushion is 5 1/2" thick.
The backrest spring is 4" thick.
I do not have a top installed but I can get you other dimensions if I know what you are looking for.
Mike
JohnM
Last Name: Michaelree
Board Member Since: 2010
Post by JohnM » Wed Dec 17, 2025 7:53 pm
Dave, on my 26 touring the distance from floor to seat top is ten and a half inches. Unless it is over stuffed, you are just a big guy. The good thing is you can put the top down. That's why I sold my Tudor sedan.
Dave1
Last Name: Eddie
Post by Dave1 » Wed Dec 17, 2025 9:48 pm
Thanks, I am not a Big Guy, at 5.10” And 165 lbs.
I also have a 26 Tudor with the OEM seat springs and it is fine for height.
JohnM
Post by JohnM » Wed Dec 17, 2025 10:37 pm
That's interesting, I'm six foot and had to squat down in the Tudor to see, I have great visability in the touring. Could it be just the thickness of the cushion padding?
Dave1
Last Name: Eddie
Post by Dave1 » Wed Dec 17, 2025 10:50 pm
John, is your spring package OEM or aftermarket?
On my 26 it has the original original seat springs, and can see through the windshield just fine.
Dave1
Last Name: Eddie
Post by Dave1 » Wed Dec 17, 2025 10:53 pm
My thoughts are that spring packages supplied by the vendors have a different gauge of wire used for the springs.
Not sure what the cure, or remedy is ?
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Wed Dec 17, 2025 11:41 pm
Dave & John,
I just measured my 26 touring seat height from the floor to the cushion top and it is 12 1/2"
When I changed my seat springs they were the same dimensions, unless you measured the broken coils but...
I overstuffed my upholstery for a softer ride, the stock upholstery padding is very thin.
I was installing custom upholstery so extra height was not an issue.
Feeling under the padding it appears that the top of the seat should be @ 11 1/2" from the floor.
Mike
Post by DanTreace » Thu Dec 18, 2025 9:35 am
From floor mat to leading rear edge in the ‘27 touring, it’s 12 1/2”
Also have added by upholstery shop added cushion as we tour lots and seat spring cushion is the only shock absorber on the T! Only 5’ 7” so top up no issues ever.
Dave1
Last Name: Eddie
Post by Dave1 » Thu Dec 18, 2025 12:53 pm
Measured from the floor to the top of the cushion,
It is 13 1/2”
Plus when you sit on the seat it does not “sag”
Two things wrong, the seat is too high and is too hard,
what to do?
It would not be a simple task cut down the seat support frame.
Post by DanTreace » Thu Dec 18, 2025 1:14 pm
If the original owner used a wood frame, that could be the cause. Or put plywood over the spring? Or stuffed the spring coils with upholstery foam, some may do that for extra support to worn coil springs.
The '26-'27 front cushion is only the spring frame, covered with the upholstery.
The cushion then fits into the metal body seat frame. Have seen some use a wood base, but not original.
Perhaps your spring may be incorrect for the '26-'27.
To fit the seat upholstery in the factory, the covering sewn assembly was fitting by compressing the spring, so that the hem of the assembly could be crimped into the channel of the spring.
seat spring compress uphol .jpg (105.53 KiB) Viewed 1153 times
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Thu Dec 18, 2025 1:48 pm
Dave,
If you send pictures of your seat frame and cushion underside then maybe we can figure out the best way to fix it.
Mike
Dave1
Last Name: Eddie
Post by Dave1 » Thu Dec 18, 2025 1:59 pm
You are correct, the last owner used plywood on the bottom beneath of the springs, this in itself adds will add 1/2” of height.
Looks like I need to take the seat apart and see what is on the top side of the spring package
Dave1
Last Name: Eddie
Post by Dave1 » Thu Dec 18, 2025 2:02 pm
[image][image][/image][/image]
Dave1
Last Name: Eddie
Post by Dave1 » Thu Dec 18, 2025 2:08 pm
JohnM
Post by JohnM » Thu Dec 18, 2025 2:43 pm
Dave, your seat upholstery looks to be well done with more padding than most. It's a shame to take it apart, but the comfort from extra padding is pointless if you can't sit in it and drive.
Here is a picture of my front seat. It is showing some wear but you can see the difference in height.
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Thu Dec 18, 2025 3:55 pm
What a shame to have to "fix" that, looks like a really nice comfortable seat.
The plywood underneath does not belong and the padding is overstuffed.
Sometimes switching the steering wheel from 17" to 16" will help get under the steering wheel but it won't raise the roof.
If the seat was "customized" is the roof still where it belongs?
It should have a curve to it and not be flat front to back
Dave1
Last Name: Eddie
Post by Dave1 » Thu Dec 18, 2025 6:40 pm
“ I think” the roofline is correct, thinking I will talk to an upholstery shop.
Yes the seat is quite comfortable, but craning your head to see, not so much.
Thanks for help.
