Proudly proclaiming nothing
Wrice123
First Name: William
Last Name: Rice
* REQUIRED* Type and Year of Model Ts owned: ‘20 touring pickup conversion, ‘25 touring
Post by Wrice123 » Sat Dec 27, 2025 8:34 pm
Ok here’s another one
New to me ‘25 touring with what seems like a dash plaque, small galvanized steel (?) rectangle riveted to the firewall just southeast of the buzzer box. I squinted both eyes then winked left and right and still can’t see any engraving on it.
Any thoughts?
Will Rice
Houston Tx
‘20 Touring Pickup
‘25 Touring
‘65 Mustang
‘24 Lighting EV
Pep C Strebeck
First Name: Joseph
Last Name: M
Re: Proudly proclaiming nothing
Post by Pep C Strebeck » Sat Dec 27, 2025 8:51 pm
Patent Plate.
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Sat Dec 27, 2025 8:54 pm
Patent Plate 1919-1925 Langs # 1965F
Post by RajoRacer » Sat Dec 27, 2025 9:54 pm
'25 should be a 2 rivet data plate.
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Sat Dec 27, 2025 10:58 pm
Well that is what I get for quoting the Langs and Snyders and Chaffins web site information.
The MTFCI Judging Standards lists the 1925 Patent plate as the 1926 style with 2 rivets and notched corners
Screenshot 2025-12-27 225138.jpg (23.46 KiB) Viewed 1022 times
Screenshot 2025-12-27 225657.jpg (25.98 KiB) Viewed 1022 times
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Sun Dec 28, 2025 4:01 am
But the OP photo shows 4 rivets.
It also has the improved transmission ears, albeit w/o the two screws.
Vern (Vieux Carre)
Post by Jerry VanOoteghem » Sun Dec 28, 2025 7:30 am
And the #3 coil is put in backwards. A lot of things can be changed over 100 years. ;)
It also has a 1926 steering column.
Last edited by Jerry VanOoteghem on Sun Dec 28, 2025 8:17 am, edited 1 time in total.
love2T's
First Name: T
Last Name: Gates
Post by love2T's » Sun Dec 28, 2025 7:52 am
Gotta love the "DIY" head gasket oozing out the joint too!
Post by RajoRacer » Sun Dec 28, 2025 12:31 pm
Let's see a photo of the doors - the door hinges will be the same length on a '25 - if the lower hinge is protruding farther out at the bottom, it could be a '24, also '25 cars had steel firewall uprights - not wooden. A true '25 will have a single rear top window.
Wrice123
First Name: William
Last Name: Rice
Post by Wrice123 » Mon Dec 29, 2025 9:35 pm
Thank you all! I guess it just the patent plate faded over time. I'll order a new plate and replace it when it comes time to make everything perdy.
Yes I'm embarassed to see in my picture I put in #3 coil backwards! We're working on it and I just temporarily pulled them out and put them back. But rest assured we're going through the whole box and contacts and will assemble it correctly!!
Interesting about the door hinges, thank you! They do appear to be the same size and not protruding farther. And yes steel firewall supports. The engine is numbered to be September 1925. The two man top has a split window, but I would guess it is not a 100 year old original but maybe was replaced 20 or 30 years ago.
It's funny that my '20 touring which was turned into a pickup still has a robe rail for the now non-existant rear seat, while this '25 touring which does have a rear seat lacks the robe rail of my pickup!
And yes the copper gasket covered in liquid gasket ooze took significant persuading from a hammer and a plastic upholstery chisel to release! We're going with the more modern replacement gasket so hopefully won't need extra ooze!
Will Rice
Houston Tx
‘20 Touring Pickup
‘25 Touring
‘65 Mustang
‘24 Lighting EV
Mike Silbert
Last Name: Silbert
Post by Mike Silbert » Mon Dec 29, 2025 10:24 pm
September 1925 Serial number is a 1926 model engine and body car.
It should be called the early '26 style.
Maybe a picture of the body and fenders would help identify it.
1926 production started August 3rd 1925
Screenshot 2025-12-29 221245.jpg (56.93 KiB) Viewed 602 times
But the block is an earlier style.
After 100 years a large amount of the Model T's are a bit mixed up.
While it is not really a problem, be careful ordering parts to get the version you actually need.
Most of us install some version of a waterproof coil box kit in our driver cars for reliability.
The robe rail was always an aftermarket accessory, it never came standard on a Model T.
Interesting it is on your pickup and not your touring.
Maybe moving it is in the future?
