FS- NORS F&F Trans Cover Aux Oiller Kits-All sets Sold
Dan McEachern
Topic author - Posts: 1506
- First Name: DAN
- Last Name: MCEACHERN
To the top-1 set remaining. All sets with the tubing and mounting bolts have been spoken for. New price for the Cover and outlet bracket only is $100.00 each including FR shipping. Extra outlet fittings- either 3 dip or 4 dip or both are available. 3/8 copper tubing and mountng bolts can be purchased locally. Thank you to everyone who purchased one!
The F&F Oiler is similar to the Ford Faithful Oiler, but only uses one gasket to seal it and is cast aluminum rather than stamped steel.. These were recently discovered in storage from a long time T parts manufacturer. A set includes the cast aluminum cover plate, the outlet fitting that attaches to the front bottom of the pan inspection plate ( your choice of either 3 or 4 dip pan), the copper tubing, tube fittings and 8 mounting bolts. Price is $100.00 /set plus $15.00 USPS priority mail shipping in the US. I only have a limited number of these and once they are sold there will be no more. Either a PM through the forum or an e-mail to dmcgearsATyahooDOTcom with your shipping address. Payment either check or F to F Paypal. Thanks
Last edited by Dan McEachern on Thu Jan 08, 2026 3:50 pm, edited 3 times in total.
Re: FS- NORS F&F Trans Cover Aux Oiller Kits
Did Max put those out ?
kmatt2
- First Name: Kevin
- Last Name: Matthiesen
Those were sold by the late Max Edmunds and haven’t been made in over 25 years as far as I know. They work well I had one on a car that I have sense since sold.
Bill Everett
- First Name: Bill
- Last Name: Everett
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1914 Touring, 1912 Roadster PickUp in process
- Board Member Since: 2011
E-Mail sent.
Dan McEachern
- First Name: DAN
Your age is showing Kevin!!
Dan McEachern
- First Name: DAN
Re: FS- NORS F&F Trans Cover Aux Oiller Kits-3 remaining
Bump to top. Only a few remaining!
- Last Name: Hatch
Email sent. I would like 2 Thanks. Dan
Stephen_heatherly
- First Name: Stephen
- Last Name: Heatherly
kmatt2
- First Name: Kevin
Re: FS- NORS F&F Trans Cover Aux Oiller Kits-1 remaining
Yes Dan you and I are getting old , but it is better than the other possibility that so many other of my Motel T friends have had happen to them, and they are not with us any more and missed .
DustySpokes
- First Name: Edmund
- Last Name: Niedzielski
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1922 Mercury Bodied Speedster, 1926-27 Roadsters /Tourings
Dan the Man. I will buy the last one if still available - Dusty
