Non-Ford cowl lamp bracket - need help to ID
Marc Roberts
Topic author - Posts: 59
- First Name: Marc
- Last Name: Roberts
- * REQUIRED* Type and Year of Model Ts owned: 1914 Runabout, 1916 Touring
Does anyone recognize these pressed steel brackets? Thanks for looking.
Re: Non-Ford cowl lamp bracket - need help to ID
I could be wrong, but I believe those are for a T.
UPDATE: Yup, I was wrong
Last edited by Jerry VanOoteghem on Fri Jan 09, 2026 12:35 pm, edited 1 time in total.
Pressed steel so not Ford, and blades are too short without offset. Don’t know make.
Chris Paulsen
- First Name: Chris
- Last Name: Paulsen
- * REQUIRED* Type and Year of Model Ts owned: 1910 Touring, 1914 Pickup
They are for an EMF.
I have seen similar ones on a 1914 T with black and brass sidelights. Some sidelights came with the brackets riveted to the light.
Allan from down under
Marc Roberts
- First Name: Marc
Thanks! I will try to get them to someone who can make good use of them.
Don
- First Name: Don
- Last Name: Azevedo
- * REQUIRED* Type and Year of Model Ts owned: 5
- Board Member Since: 2003
Chris is correct. They are off an EMF.
- Last Name: House
I know what the are !! They’re $10 @ pair Swap Meet brackets
