'26 - '27 brake cam levers
Chad_Marcheese
First Name: Chad
Last Name: Marcheese
* REQUIRED* Type and Year of Model Ts owned: 1925 Cut Off Touring / Pickup, 1923 Speedster Gow Job
Post by Chad_Marcheese » Mon Jan 12, 2026 8:01 pm
Are the brake cam levers for a '26-'27 the same left and right?
I know the cams are different for each side.
Thank you
Mike Silbert
Last Name: Silbert
Re: '26 - '27 brake cam levers
Post by Mike Silbert » Mon Jan 12, 2026 10:17 pm
The levers should be the same right and left
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Mon Jan 12, 2026 11:00 pm
The cams are right and left. The arms are the same.
Chad_Marcheese
First Name: Chad
Post by Chad_Marcheese » Tue Jan 13, 2026 5:33 am
Thank You Mike and Mark. That's what I was hoping you'd say.
