Need a bigger carburetor?
First Name: Austin
Last Name: Farmer
Post by 1925 Touring » Fri Jan 16, 2026 9:24 pm
I took this picture at work about a year ago. It's a little humerous to compare parts from my T to other things sometimes. For some reason I took my carb to work one day to mess with after hours. On the table was a different carburetor, a carburetor for a T-28, or more specifically an R-1820-86b.
I didn't take the cover off, not at a rebuild price of $11,000. Still think T's are expensive? ;)
Think it will bolt onto the T?
Re: Need a bigger carburetor?
Post by TXGOAT2 » Sat Jan 17, 2026 10:40 am
I wonder what sort of carburetors Ford used on the Tri-motor?
Last Name: Juhl
Post by Oldav8tor » Sat Jan 17, 2026 12:57 pm
Sorry to hijack the thread somewhat, but the engines used in the Ford developed 420 HP - must have been bigger carbs than a Model T's but less than a T-28. That said, there are a few Model A parts that showed up in the trimotor. Interestingly, a place that specializes in rebuilding them is here in Michigan. They have the dies for the corrugated skin and other specialty tools to do the job.
Last Name: Hatch
Post by Dan Hatch » Sat Jan 17, 2026 1:00 pm
Many years ago there was a shop in town that specializes in Carburetors. On their counter was a carb off a B17. That thing was huge! Dan
Post by TXGOAT2 » Sat Jan 17, 2026 1:05 pm
A machine shop here once had a big double row radial crankshaft on the bench. Some local oil guys had a number of WW2 planes and they flew them a lot.
First Name: Austin
Last Name: Farmer
Post by 1925 Touring » Sun Jan 18, 2026 12:15 am
Likely the same type as the ones we play with. The B 17s used R1820s. The T 28s do as well, although with a few changes.
