1924 fender to running board question
cwlittle
First Name: Charles
Last Name: Little
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1924 Del. Truck, 1924 Touring
Post by cwlittle » Fri Jul 12, 2019 3:15 pm
I understand that instead of a wooden block between the front fender and running board there was two "spacers". Were these essentially thick washers? And how thick were they?
Charlie Little, South Paris, Maine
sweet23
First Name: Darryl
Last Name: Bobzin
Re: 1924 fender to running board question
Post by sweet23 » Fri Jul 12, 2019 6:41 pm
Yes the earlier fenders had a washer between the fender and the running board. In '25 the fenders were modified to have a raised area around the bolt holes, eliminating the need for the washer. R. V. Anderson makes a bolt kit for the fenders & running boards that has the correct washer included.
Post by Original Smith » Fri Jul 12, 2019 6:57 pm
Just use a relatively thick 5/16" washer about the same diameter as a quarter.
cwlittle
First Name: Charles
Last Name: Little
Post by cwlittle » Sat Jul 13, 2019 7:11 am
THANKS for the info!
