WTB. FORD T Water, gas, oil canister with mounting brackets.
Thanks Larry
Re: WTB Gas, Oil, Water canisters.
Daisy Mae
- First Name: Kurt
- Last Name: Andersson
- Board Member Since: 2024
Re: Re: WTB Gas, Oil, Water canisters.
Bottom line you'll only find them with some luck.
Original Boyco's & such can still come up for sale like here or Ebay, or be found in antique stores, swap meets, etc. Just keep your eye out, but they tend to be very pricey.
There had been some reproduction 'Boyco' copies made years past, but no longer. I actually snagged the last display set Lang's had. But the repros were pretty much display, and not truly functional, so if you find a repro set just be aware they'd require some soldering to be functional.
