E&j Cowl and tail lamp question
Karl Von Neumann
Topic author - Posts: 884
- First Name: Karl
- Last Name: VonNeumann
- * REQUIRED* Type and Year of Model Ts owned: 1916 touring 1927 tudor 1926 hotrod 1913 speedster (project) 1926 coupe (project)
- Board Member Since: 2022
Are all the e&j pat 1908 cowl and tail lamps the same size? I'm making the brass antitarnish covers and I need to know. I tried my covers on a 13 of a chapter friend and it fit fine just want to make sure be fore I post that it fits all patient 08 lamps when it might not. Thanks for the wisdom guys
- Last Name: House
Re: E&j Cowl and tail lamp question
Yes they are. Your lamp covers should also fit 1914 E&J Model 32s…
Karl Von Neumann
- First Name: Karl
Thanks GeorgeGeorge House wrote: ↑Sun Feb 01, 2026 4:19 pmYes they are. Your lamp covers should also fit 1914 E&J Model 32s…
Russ_Furstnow
- First Name: Russ
- Last Name: Furstnow
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1911 Torpedo,1913 Touring, 1914 Runabout, 1915 Coupelet, 1916 Coupelet, 1917 Coupelet
Karl, Some early 1909 Fords came with three tier sidelamps, and they are larger than a two tier sidelamp. I hope this helps. Russ Furstnow
Karl Von Neumann
- First Name: Karl
Russ I have heard that as well and I have a 3 tier e&j here its huge! That's why I'm trying to find out all the sizes etc. Working thru the list of headlights as wellRuss_Furstnow wrote: ↑Mon Feb 02, 2026 8:48 amKarl, Some early 1909 Fords came with three tier sidelamps, and they are larger than a two tier sidelamp. I hope this helps. Russ Furstnow
