quick bolt set ( reproduction )
Gene_French
First Name: Gene
Last Name: French
Board Member Since: 2014
Post by Gene_French » Tue Feb 03, 2026 3:31 pm
i have finished another short run of mainbearing quick bolts for model A and T Ford engines ... these speed up the tedious process of fitting the mainbearings ...most often used in re-fitting used bearings with the engine on a stand ...price is $150.00 + $12.95 postage in lower 48 states ...actual postage outside this area or INTERNATIONAL ... contact me thru the MTFCA site ...Gene French
